AS1100,pdf (8-Digit LED driver
消耗积分:5 | 格式:rar | 大小:333 | 2010-09-06
分享资料个
The AS1100 is an LED driver for 7 segment numeric displays of up to 8 digits. The AS1100 can be programmed via a conventional 4-wire serial interface. It includes a BCD code-B decoder, a multiplex scan circuitry, segment and display drivers and a 64-Bit memory.
The memory is used to store the LED settings, so that continuous reprogramming is not necessary. Every individual segment can be addressed and updated separately. Only one external resistor is required to set the current through the LED display. Brightness can be controlled either in an analog or digital way. The user can choose the internal code-B decoder to display numeric digits or to address each segment directly.
The AS1100 features an extremely low shutdown current of only 20µA and an operational current of less than 500µA. The number of visible digits can be programmed as well. The AS1100 can be reset by software and an external clock can be used. Several test modes support easy debugging. The AS1100 is fully compatible to the MAX 7219. AS1100 is offered in a 24-pin PDIP and SOIC package.
评论(0)
发评论
下载排行榜
