The INA199Ax series of voltage output current shunt monitors can sense drops across shunts at common-mode voltages from –0.3V to 26V, independent of the supply voltage. Three fixed gains are available: 50V/V, 100V/V, and 200V/V. The low offset of the Zerø-Drift architecture enables current sensing with maximum drops across the shunt as low as 10mV full-scale.
These devices operate from a single +2.7V to +26V power supply, drawing a maximum of 100µA of supply current. All versions are specified from –40°C to +105°C, and offered in both SC70 and thin QFN-10 packages.
