VCA2612,pdf(Dual, Variable Gai
消耗积分:3 | 格式:rar | 大小:560 | 2010-09-27
分享资料个
The VCA2612 is a highly integrated, dual receive channel, signal processing subsystem. Each channel of the product consists of a low noise preamplifier (LNP) and a Variable Gain Amplifier (VGA). The LNP circuit provides the necessary connections to implement Active Termination (AT), a method of cable termination which results in up to 4.6dB noise figure improvement. Different cable termination characteristics can be accommodated by utilizing the VCA2612\x92s switchable LNA feedback pins. The LNP has the ability to accept both differential and single-ended inputs, and generates a differential output signal. The LNP provides strappable gains of 5dB, 17dB, 22dB, and 25dB.
The output of the LNP can be accessed externally for further signal processing, or fed directly into the VGA.
评论(0)
发评论
下载排行榜
