FT8010,pdf (Reset Timer with C
消耗积分:5 | 格式:rar | 大小:433 | 2010-09-30
分享资料个
The FT8010 is a timer for resetting a mobile device
where long reset times are needed. The long time delay
helps avoid unintended resets caused by accidental key
presses. Two delays can be selected by hard-wiring the
DSR pin: 7.5 ±20% seconds or 11.25 ±20% seconds.
The FT8010 has two identical inputs for single or dual
switch resetting capability. The device has two outputs:
a push-pull output with 0.5mA drive and an open-drain
output with 0.5mA pull-down drive.
The FT8010 draws minimal ICC current when inactive
and functions over a wide power supply range of 2.0V to 5.0V.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
