TPS65030,pdf(Power Management
消耗积分:3 | 格式:rar | 大小:981 | 2010-10-04
王杰
分享资料个
The TPS65030 contains three charge pumps and one LDO to generate all supply voltages necessary for an USB On-The-Go (OTG) implementation using TUSB6010. The charge pumps are optimized for a single Li-Ion cell input or for 5 V from the USB bus. The input voltage range is 3 V to 5 V for the battery voltage. High efficiency is achieved by using fractional conversion techniques for the charge pumps in combination with a power saving sleep mode. The current controlled charge pumps in addition ensure low input current ripple and low EMI. Small size external ceramic capacitors are required to build a complete power supply solution. To reduce board space to a minimum, the device switches at 1-MHz operating frequency, and is available in a small 25-ball chip scale package (YZK).
评论(0)
发评论
下载排行榜
