TL7702B,TL7705B,TL7733B,pdf(SU
消耗积分:5 | 格式:rar | 大小:620 | 2010-10-23
绝代双骄
分享资料个
The TL7702B, TL7705B, and TL7733B are integrated-circuit supply-voltage supervisors designed for use as reset controllers in microcomputer and microprocessor systems. The supply-voltage supervisor monitors the supply for undervoltage conditions at the SENSE input. During power up, the RESET\ output becomes active (low) when VCC attains a value approaching 1 V. As VCC approaches 3 V (assuming that SENSE is above VT+), the delay timer function activates a time delay, after which outputs RESET\ and RESET go inactive (high and low, respectively). When an undervoltage condition occurs during normal operation, outputs RESET\ and RESET go active. To ensure that a complete reset occurs, the reset outputs remain active for a time delay after the voltage at the SENSE input exceeds the positive-going threshold value.
评论(0)
发评论
下载排行榜
