Thank you for using TXLine Version 1.1!
The following is the latest information on TXLine.
To reduce the size of the TXLine files, no setup program is provided. However setting up the program is very simple. All the files extracted from the TXLINE.ZIP file need to be in the directory that the program will be executed from. If you want to create an icon for the program, then you need to manually add the program item through the Windows Program Manager (or through Explorer in Windows 95). Consult your Windows documentation for adding program icons to the Program Manager (or Explorer in Windows 95).
