DS1868 pdf datasheet (Dual Dig
消耗积分:5 | 格式:rar | 大小:666 | 2008-10-04
吴湛
分享资料个
The DS1868 has two 256-position potentiometers, with wiper positions each set as 8-bit values. The potentiometers can be used independently or stacked for increased total resistance and number of taps. Communication takes place through a 3-wire serial port interface that drives an internal control logic unit. Multiple DS1868s can be linked or daisy-chained for control by a single processor.
The DS1868 +5-volt Dual Digital Potentiometer was designed for applications requiring extremely low current consumption and extremely low cost. Maximum standby current is 1µA. The DS1868 is based on DS1267 technology but operates from a single +5-volt or from dual ±3-volt supplies.
Digital potentiometers improve upon mechanical devices with processor control and programmability, greater reliability and accuracy, and packaging options that facilitate automatic assembly. They are used for signal control in modems and phones, battery charging and control circuitry, tuning and calibration, offset trimming of operational amplifiers, gain control, and power supply regulation.
  • Two 256-position digital potentiometers
  • Wipers digitally set and read through serial port
  • EEPROM maintains settings in the absence of power
  • Ultra low-power consumption: max standby current of 1µA
  • 3-wire serial control interface
  • Operating ranges:
    • +5V or ±3V
    • -40°C to +85°C
  • 声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容侵权或者其他违规问题,请联系本站处理。 举报投诉
    评论(0)
    发评论
    下载排行榜
