MAX1407, MAX1408 pdf datasheet
消耗积分:5 | 格式:rar | 大小:666 | 2008-10-06
分享资料个
The MAX1407/MAX1408/MAX1409/MAX1414 are lowpower,
general-purpose, multichannel data-acquisition
systems (DAS). These devices are optimized for lowpower
applications. All the devices operate from a single
+2.7V to +3.6V power supply and consume a
maximum of 1.15mA in Run mode and only 2.5μA in
Sleep mode.
The MAX1407/MAX1408/MAX1414 feature a differential
8:1 input multiplexer to the ADC, a programmable
three-state digital output, an output to shutdown an
external power supply, and a data ready output from
the ADC. The MAX1408 has eight auxiliary analog
inputs, while the MAX1407/MAX1414 include four auxiliary
analog inputs and two 10-bit force/sense DACs.
The MAX1414 features a 50mV trip threshold for the
signal-detect comparator while the others have a 0mV
trip threshold. The MAX1409 is a 20-pin version of the
DAS family with a differential 4:1 input multiplexer to the
ADC, one auxiliary analog input, and one 10-bit
force/sense DAC.
The MAX1407/MAX1408/MAX1414 are available in
space-saving 28-pin SSOP packages, while the
MAX1409 is available in a 20-pin SSOP package.
Applications
Medical Instruments
Industrial Control Systems
Portable Equipment
Data-Acquisition System
Automatic Testing
Robotics
评论(0)
发评论
下载排行榜
