铂电阻测温非线性补偿的研究
消耗积分:10 | 格式:rar | 大小:145 | 2010-12-09
分享资料个
 针对铂电阻在测量温度中存在的非线性,分析了产生非线性误差的主要原因,讨论了改善铂电阻线性度以及消除测量电路非线性误差的方法,为铂电阻的非线性补偿方法提供了理论依据。最后给出误差分析和实验结论。
Abstract:
 In accordance with the nonlinearity of platinum resistors in temperature measurement, the principal of nonlinear errors are analyzed,the methods of reducing nonlinear errors are discussed. The theory basis for the nonlinear compensation method of platinum resistance is offered. The related error analysis and test results are presented.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
