基于AD9516的时间交叉采样时钟的设计
消耗积分:0 | 格式:rar | 大小:5411 | 2010-12-16
ljqj1
分享资料个
 针对四通道时间交叉采样对时钟的严格要求,提出了使用时钟分配器AD9516给四个交叉采样的模数转换器AD9445提供四路在相位上严格相差90°的110 MHz的采样时钟。在介绍AD9516特性的基础上,详细说明了系统设计电路结构,并利用FPGA模拟高速同步串行口(SPI)协议,实现了DSP利用FPGA当作桥接器件和AD9516通信。
Abstract:
 As to the strict requirement of four channel time-interleaved sampling for clock,a new method that uses clock buffer AD9516 to provide four sampling clocks of 110MHz which differ by 90°in phase for four time-interleaved analog-to-digital converter is introduced in this paper.The characteristics of AD9516 and the circuit diagram are presented in detail. Making use of FPGA to simulate SPI protocol,the communication between AD9516 and DSP is realized by using the FPGA as bridge chip.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
