基于盲源分离的同道数字通信干扰抑制
消耗积分:3 | 格式:rar | 大小:594 | 2010-12-25
分享资料个
数字通信方式广泛应用于无线通信,但由于无线信道的开放性,接收信号易受同道信号干扰。分析了盲源分离理论抑制同道干扰的可行性,并采用著名的盲源分离算法—FastICA算法进行计算机仿真,结果表明,可采用FastICA算法分离同道的BASK和QPSK及BPSK和BFSK信号,并消除同道干扰。
Abstract:
 Digital communications system is widely used in current wireless communication.However because of the open-ing of the wireless channel,the received signal often is interferenced by co-channel signal.We analysis the valadity of blind source separation applied in co-channel interference restraint and apply FastICA algorithm to separate BASK and QPSK,BPSK and BFSK,the simulation results show the validity.
评论(0)
发评论
下载排行榜
