探讨应用GL Studio辅助开发仿真雷达显示器。首先直接对所要显示的图形符号及数字静态建模,然后对其中需要动态变化的部分调用API函数进行实时驱动,最终实现常规、偏心雷达平面位置显示器(PPI)的仿真。该雷达显示器仿真明显减少了直接从底层开发所需的工作量,仿真界面清晰,目标运动实时性好。
- Abstract:
- Application of GL Studio in the simulation is discussed in the paper.At first,staticly modeling all thegraphic symbols and numbers that needed to be shown by virtue of the modeling software,then dynamic parts such as some points and figures are driven through API function calls.Simulation of general and eccentric radar PPI display is implemented in the end.The result shows that the simulation of radar display with GL Studio has shorter development period,furthermore,it has legible simulation interface and can meet the requirement of real time.
