GPIB命令的数据结构
消耗积分:0 | 格式:rar | 大小:571 | 2011-01-04
wadsn3333
分享资料个
针对GPIB命令的结构,提出一种存储GPIB命令的数据结构。根据GPIB命令的层次关系的特点,选择数据结构中“树”的概念来存储GPIB命令结点;并考虑程序实现的效率问题以及管理维护方面的因素,对普通的树进行改造,从而形成特有的“GPIB命令树”。
Abstract:
 In this paper,aiming at the structure of GPIB command,a new data structure which is used to store GPIB com-mand is put forward.Considering the hierarchy of GPIB command is very clear,the concept of tree in data structure is se-lected to store GPIB command nodes.And taking the efficiency of program implementation and the factors of administration and maintenance into consideration,this paper transforms the normal tree to a special“GPIB Tree”.
评论(0)
发评论
下载排行榜
