TK11227/TK11230/TK11232 pdf da
消耗积分:3 | 格式:rar | 大小:555 | 2008-10-24
刘洋
分享资料个
The TK11227/TK11230/TK11232 is a low power, linear regulator with a builtin
electronic switch. The internal electronic switch can be
controlled by TTL or CMOS logic levels. The device is in
the ON state when the control pin is pulled to a high logic
level. A pin for a bypass capacitor is provided, which
connects to the internal circuitry, to lower the overall output
noise level.
An internal PNP pass-transistor is used in order to achieve
low dropout voltage (typically 100 mV at 30 mA load
current). The device has very low quiescent current (180
mA) in the ON mode with no load and 1 mA with 30 mA load.
The quiescent current is typically 2.5 mA at 60 mA load.
When the device is in standby mode (VCONT = 0), the
quiescent current is typically 100 nA. An internal thermal
shutdown circuit limits the junction temperature to below
150 °C. The load current is internally monitored and the
device will shut down in the presence of a short circuit at the
output.
评论(0)
发评论
下载排行榜
