The VL5510 is a 0.13 μm CMOS digital camera featuring a high dynamic range (1024 x 512 resolution) for automotive applications. This complete camera module is ready to connect to the camera enabled baseband processor. Video data is output from the VL5510 over a 12-bit parallel interface and a high speed serial link (8/10/12 bits raw data output format supported on the compact camera port (CCP) interface compatible with an SMIA (standard mobile imaging architecture) normative. Control interface is an SPI (serial peripheral interface) or UART (universal asynchronous receiver transmitter) interface or I2C (Inter Integrated Circuit) interface. Power supplies delivered to the sensor are: ● 3.3 V for the analog blocks, ● 3.3 V for the digital interface, ● 2.5 V for the high speed serial link interface, ● 1.2 V for the internal digital core (generated internally using a low drop output regulator). The VL5510 is designed to operate in conjunction with an electronic central unit (ECU) that manages the device in the car. An input clock is required in the range 6 MHz to 27.77 MHz. The device contains an embedded video processor and delivers monochrome processed images at up to 34 frames per second. The video processor integrates a wide range of image enhancement functions, designed to ensure high image quality. These include: ● Antidark sun correction ● Dark calibration ● Vertical fix pattern correction ● Frame crop ● Defect pixel correction ● Test patterns generation ● Statistics generation (histogram) ● Sensor status data embedding (SCL, trailer)
