The RT9004 is designed for portable RF and wireless applications with demanding performance and space requirements. The RT9004 performance is optimized for battery-powered systems to deliver ultra low noise and low quiescent current. Regulator ground current increases only slightly in dropout, further prolonging the battery life. The RT9004 also works with low-ESR ceramic capacitors, reducing the amount of board space necessary for power applications, critical in hand-held wireless devices. The RT9004 consumes less than 0.01uA in shutdown mode and has fast turn-on time less than 50us. RT9004 is short circuit thermal folded back protected. RT9004 lowers its OTP trip point from 165°C to 110°C when output short circuit occurs (VOUT < 0.4V) providing maximum safety to end users. The other features include ultra low dropout voltage, high output accuracy, current limiting protection, and high ripple rejection ratio. Available in the VDFN-10L 3x3 and WDFN-10L 3x3 packages, the RT9004 also offers custom voltage, range of 1.5V to 3.5V with 0.1V per step.
