DS9193/DS9193-08 pdf datasheet
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-11
分享资料个
The RT9193 is designed for portable RF and wireless
applications with demanding performance and space
requirements. The RT9193 performance is optimized for
battery-powered systems to deliver ultra low noise and
low quiescent current. A noise bypass pin is available for
further reduction of output noise. Regulator ground current
increases only slightly in dropout, further prolonging the
battery life. The RT9193 also works with low-ESR ceramic
capacitors, reducing the amount of board space necessary
for power applications, critical in hand-held wireless
devices. The RT9193 consumes less than 0.01μA in
shutdown mode and has fast turn-on time less than 50μs.
The other features include ultra low dropout voltage, high
output accuracy, current limiting protection, and high ripple
rejection ratio. Available in the 5-lead of SC-70, SOT-23
and WDFN-6L 2x2 packages.
评论(0)
发评论
下载排行榜
