AT102TN01 pdf datasheet
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-12
吴湛
分享资料个
INNOLUX DISPLAY CORPORATION LCD MODULE SPECIFICATIOSPECIFICATION
General Specifications
No. Item Specification Remark
1 LCD size 10.2 inch(Diagonal)
2 Driver element a-Si TFT active matrix
3 Resolution 800X3(RGB)X480
4 Display mode Normally white, Transmissive
5 Dot pitch 0.0925(W)X0.276(H) mm
6 Active area 222.0(W)X132.48(H) mm
7 Module size 235.0(W)X145.8(H)X6.1(D) mm Note 1
8 Surface treatment Anti-Glare
9 Color arrangement RGB-stripe
10 Interface Digital
11 Backlight power consumption 4.098W(Typ.)
12 Panel power consumption 250mW(Typ.)
13 Weight 332g(Typ.)
评论(0)
发评论
下载排行榜
