Features • This Circuit is Processed in Accordance to MIL-STD- 883 and is Fully Conformant Under the Provisions of Paragraph 1.2.1. • 0MHz to 25.6MHz Sample Rate • Four Filter Cells • 8-Bit Coefficients and Signal Data • Low Power CMOS Operation - ICCSB = 500μA Maximum - ICCOP = 110μA Maximum at 20MHz • 26-Bit Accumulator Per Stage • Filter Lengths Up To 1032 Taps • Expandable Coefficient Size, Data Size and Filter Length • Decimation by 2, 3 or 4 Applications • 1-D and 2-D FIR Filters • Radar/Sonar • Adaptive Filters • Echo Cancellation • Complex Multiply-Add • Sample Rate Converters
