AX88796L pdf datasheet (3-in-1
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-25
分享资料个
The AX88796 Fast Ethernet Controller is a high performance and highly integrated local CPU bus Ethernet Controller
with embedded 10/100Mbps PHY/Transceiver and 8K*16 bit SRAM. The AX88796 supports both 8 bit and 16 bit local
CPU interfaces include MCS-51 series, 80186 series, MC68K series CPU and ISA bus. The AX88796 implements both
10Mbps and 100Mbps Ethernet function based on IEEE802.3 / IEEE802.3u LAN standard. The AX88796 also provides
an extra IEEE802.3u compliant media-independent interface (MII) to support other media applications. Using MII
interface, Home LAN PHY type media can be supported.
As well as, the chip also provides optional Standard Print Port ( parallel port interface ), can be used for printer server
device or treat as simple general I/O port. The chip also support upto 3/1 additional General Purpose In/Out pins
评论(0)
发评论
下载排行榜
