HA-5020 pdf datasheet (100MHz
消耗积分:2 | 格式:rar | 大小:336 | 2009-01-06
李鸿
分享资料个
The HA-5020 is a wide bandwidth, high slew rate amplifier
optimized for video applications and gains between 1 and
10. Manufactured on Intersil’s Reduced Feature
Complementary Bipolar DI process, this amplifier uses
current mode feedback to maintain higher bandwidth at a
given gain than conventional voltage feedback amplifiers.
Since it is a closed loop device, the HA-5020 offers better
gain accuracy and lower distortion than open loop buffers.
The HA-5020 features low differential gain and phase and
will drive two double terminated 75Ω coax cables to video
levels with low distortion. Adding a gain flatness
performance of 0.1dB makes this amplifier ideal for
demanding video applications. The bandwidth and slew rate
of the HA-5020 are relatively independent of closed loop
gain. The 100MHz unity gain bandwidth only decreases to
60MHz at a gain of 10. The HA-5020 used in place of a
conventional op amp will yield a significant improvement in
the speed power product. To further reduce power, HA-5020
has a disable function which significantly reduces supply
current, while forcing the output to a true high impedance
state. This allows the outputs of multiple amplifiers to be
wire-OR’d into multiplexer configurations. The device also
includes output short circuit protection and output offset
voltage adjustment.
For multi channel versions of the HA-5020 see the HA5022
dual with disable, HA5023 dual, HA5013 triple and HA5024
quad with disable op amp data sheets.
评论(0)
发评论
下载排行榜
