HA-5134 pdf datasheet (4MHz, P
消耗积分:3 | 格式:rar | 大小:222 | 2009-01-08
刘杰
分享资料个
The HA-5134 is a precision quad operational amplifier that is
pin compatible with the OP-400, LT1014, OP11, RM4156,
and LM148 as well as the HA-4741. Each amplifier features
guaranteed maximum values for offset voltage of 200μV,
offset voltage drift of 2μV/oC, and offset current of 75nA over
the full temperature range while CMRR/PSRR is guaranteed
greater than 94dB and AVOL is guaranteed above 500kV/V
over the full temperature range.
Precision performance of the HA-5134 is enhanced by a
noise voltage density of 7nV/√Hz at 1kHz, noise current
density of 1pA/√Hz at 1kHz and channel separation of
120dB. Each unity-gain stable quad amplifier is fabricated
using the dielectric isolation process to assure performance
in the most demanding applications.
The HA-5134 is ideal for compact circuits such as
instrumentation amplifiers, state-variable filters, and lowlevel
transducer amplifiers. Other applications include
precision data acquisition, precision integrators, and
accurate threshold detectors in designs where board space
is a limitation.
For military grade product, refer to the HA-5134/883 data sheet.
评论(0)
发评论
下载排行榜
