(1)所有综合工具都支持的结构always, assign, begin, end, case, wire, triaupplyo, supply 1, reg, integer, default, for, function and, nand, or, nor,Xorxnor buf not bufifo bufiotifpunstantitationmodule, negedge, posedge, operators, output, parameter
(2)所有综合工具都不支持的结构me, defparam, Finish, fork, joinadelays, Udp wai
(3)有些工具支持有些工具不支持的结构case. casearianaor. triorreadisablearraysemories, repeat, task, while
