HS-80C86RH pdf datasheet (Radi
消耗积分:3 | 格式:rar | 大小:233 | 2009-01-09
golabs
分享资料个
The Intersil HS-80C86RH high performance radiation
hardened 16-bit CMOS CPU is manufactured using a
hardened field, self aligned silicon gate CMOS process. Two
modes of operation, MINimum for small systems and
MAXimum for larger applications such as multiprocessing,
allow user configuration to achieve the highest performance
level. Industry standard operation allows use of existing
NMOS 8086 hardware and software designs.
Specifications for Rad Hard QML devices are controlled
by the Defense Supply Center in Columbus (DSCC). The
SMD numbers listed here must be used when ordering.
Detailed Electrical Specifications for these devices are
contained in SMD 5962-95722. A “hot-link” is provided
on our homepage for downloading.
评论(0)
发评论
下载排行榜
