开源硬件-PMP9091.2-12V 输入、3W、双路 5V 输出降压稳压器 PCB layout 设计
消耗积分:0 | 格式:pdf | 大小:156.75KB | 2021-03-05
王刚
分享资料个
This supply uses the TPS54160 buck regulator to generate a 5V/0.5A regulated output and an auxilliary 5V/0.2A unregulated output.  A two winding coupled inductor is used to generate the auxilliary output.   The auxilliary output is left floating, and could be used as a -5V output or (...)
评论(0)
发评论
下载排行榜
