EL6935/EL6935B pdf datasheet (
消耗积分:3 | 格式:rar | 大小:433 | 2009-01-16
分享资料个
The EL6935B is a highly integrated laser diode driver
designed to support multi-standard writable optical drives. It
accomplishes this by incorporating a waveform generator
wherein the diode currents and timing details can be
programmed before operation. The generator inspects the
NRZ serial data waveform and generates programmed
waveforms in recognition of 3, 4, 5, or 6 or more clock
periods of space changing to 3, 4, 5, or 6 or more clock
periods of mark, and vice versa. The part also has an IV
amplifier with concurrent read and write sampling. The gains
of the IV amplifier are programmable, eliminating the need
for external potentiometers.
The flexible architecture supports different media and
speeds for Blue, DVD, and CD standards. The programming
is accomplished through a serial interface port. The clock
and NRZ inputs can be either stand
评论(0)
发评论
下载排行榜
