ISL54214 pdf datasheet (USB 2.
消耗积分:2 | 格式:rar | 大小:555 | 2009-01-17
分享资料个
The Intersil ISL54214 is a single supply dual SP3T analog
switch that operates from a single supply in the range of 2.7V
to 4.6V. It was designed to multiplex between audio stereo
signals and two different USB 2.0 high speed differential data
signals. The audio channels allow signal swings below
ground, allowing the multiplexing of the voice and data signals
through a common headphone connector in Personal Media
Players and other portable battery powered devices.
The audio switch cells can pass ±1V ground referenced audio
signals with very low distortion (<0.03% THD+N when driving
5mW into 32Ω loads). The USB switch cells have very low ON
capacitance (8pF) and high bandwidth to pass USB high
speed signals (480Mbps) with minimal edge and phase
distortion.
The ISL54214 is available in a tiny 12 Ld 2.2mmx1.4mm
ultra-thin QFN and 12 Ld 3mmx3mm TQFN packages. It
operates over a temperature range of -40 to +85°C.
评论(0)
发评论
下载排行榜
