ISL65426/ISL65426MREP pdf data
消耗积分:2 | 格式:rar | 大小:322 | 2009-02-07
小组店小二
分享资料个
The ISL65426MREP is a high efficiency dual output monolithic synchronous buck converter operating over an
input voltage range of 2.5V to 5.5V. This single chip power
solution provides two output voltages which are selectable or
externally adjustable from 1.2V to 80% of the supply voltage
while delivering up to 6.0A of total combined output current
when used at TJ of +125°C or less. The two PWMs are
synchronized 180° out of phase reducing the RMS input current and ripple voltage.
评论(0)
发评论
下载排行榜
