SMSC负荷状态检测方法研究
消耗积分:3 | 格式:rar | 大小:333 | 2009-02-21
分享资料个
对短消息服务中心的负荷状态检测方法作了探讨。在研究系统负荷状态与内部资源关系的基础上,给出了负荷状态检测参数、检测模型及基于多参数数据融合的检测方法,并通过实验测试结果对其有效性进行了分析。研究表明,系统的负荷状态可以通过对多种内部资源消耗量的检测进行评价,多参数冗余信息融合后可以提高结果的可靠性和置信度。
关 键 词 短消息服务中心; 负荷检测; 数据融合; 负荷控制
Abstract Some thoroughly research on load state detection in SMSC entity is introduced in this paper. Load detection parameters and model are presented after analyzing the relationship between inter resource and load state in the system. Moreover, a novel strategy to detect system load state based on fusion of multi detection data is presented. By some test, the theory and method are proved most feasible. Our research show that load state of SMSC can be recognized by detecting utility of internal resource utilizing, and multi redundant detecting data fusion is effective approach to improve the reliability and trust degree of the result.
Key words short message service center; load detection; data fusion; load control
评论(0)
发评论
下载排行榜
