MAX9382, MAX9383 pdf datasheet
消耗积分:5 | 格式:rar | 大小:332 | 2009-02-21
ejlwj
分享资料个
The MAX9382/MAX9383 are high-speed PECL/ECL phase-frequency detectors designed for use in high-bandwidth phase-locked loop (PLL) applications. The devices compare a single-ended reference (R) and a VCO (V) input and produce pulse streams on differential up (U) and down (D) outputs. When integrated, the difference of the output pulse streams provides a control voltage proportional to input phase or frequency difference. Guaranteed minimum short pulse duration completely eliminates minimum phase difference requirements during the lock condition, maximizing loop jitter performance.
The MAX9382/MAX9383 feature low propagation and reset delay, making them ideal for high-frequency clock synchronization use. The MAX9382 uses 100K logic levels, has a supply voltage range of VCC - VEE = 4.2V to 5.5V, and is pin compatible with Motorola's MCK12140. The MAX9383 uses 10H logic levels with a supply voltage range of VCC - VEE = 4.75V to 5.5V and is pin compatible with the MCH12140.
The MAX9382/MAX9383 are available in industry-standard 8-pin SO and space-saving 8-pin µMAX packages.
评论(0)
发评论
下载排行榜
