Pokemon-Terminal
口袋妖怪终端,目前包含了 493 个不同的口袋妖怪主题背景,可以根据命令选择口袋妖怪,还内置了搜索口袋妖怪的功能, 支持 iTerm2、Terminology 及 Tilix 终端。
功能特性:
493 个独特的口袋妖怪
可按名称或索引号选择口袋妖怪
可更改桌面壁纸和终端背景
内置搜索口袋妖怪功能
支持 iTerm2、Terminology 、 Tilix
示例:
Usage: pokemon [parameter] ichooseyou [parameter] Parameters: [name] - Change the terminal background to the specified Pokemon. [index] - Change the terminal background to a Pokemon by its index. [region] - List all the Pokemon of the specified region. [one letter] - List all Pokemon who's names begin with a particular letter. [two letters] - List all Pokemon who's names begin with those two letters. Other Parameters: all - List all the Pokemon supported. regions - List all the available regions. extra - List all the Pokemon from the 'Extra' folder. random - Change the terminal background to a random Pokemon. random-- Change the terminal background to a random Pokemon from the specified region. slideshow [time] - Iterate through each Pokemon. Optional time (in seconds) between Pokemon. slideshow- [time] - Iterate through each Pokemon in the specified region. Optional time (in seconds) between Pokemon. rnd-slideshow [time] - Iterate through each Pokemon in a random order. Optional time (in seconds) between Pokemon. rnd-slideshow- [time] - Iterate through each Pokemon in the specified region in a random order. Optional time (in seconds) between Pokemon. light - Change the terminal background to a random light-colored Pokemon. dark - Change the terminal background to a random dark-colored Pokemon. type [type] - Change to a random pokemon of said type. clear | disable | off - Clear the Pokemon in the terminal. help - Display this menu. Wallpaper Parameters: pokemon _pikachu - Change the wallpaper to the specified Pokemon. pokemon _random - Change the wallpaper to a random Pokemon. pokemon _random-kanto - Change the wallpaper to a random Pokemon from the specified region. Search System Information: Any input containing 3 or more characters triggers the internal search system. Examples: "pokemon pika" changes the terminal background to Pikachu. "pokemon dos" changes the terminal background to Gyarados.
