The ML2280 and ML2283 are 8-bit successive approximation A/D converters with serial I/O and configurable input multiplexers with up to 4 input channels.
All errors of the sample-and-hold incorporated on the
ML2280 and ML2283 are accounted for in the analog-todigital
converters accuracy specification.
The voltage reference can be externally set to any value
between GND and VCC, thus allowing a full conversion
over a relatively small voltage span if desired.
The ML2283 is an enhanced double polysilicon, CMOS,
pin-compatible second source for the ADC0833 A/D
converter. All parameters are guaranteed over temperature
with a power supply voltage of 5V ±10%.
