此转换器提供 12V/5A 的高功率 PoE 输出。TPS2379 PD 控制器允许使用外部热插拔 FET 以提高效率。UCC2897A PWM 控制器用于实施高效的有源钳位正向转换器。
特性
High efficiency (90% with PoE supply, 93.6% with adapter supply)
12V at 5A output
Isolated Forward with synchornous rectifier
Uses TPS2379 combined with UCC2897A to implement a high efficiency active forward converter
Allows an external hot swap FET for increased efficiency
This circuit design is full-functional tested and recommended for new designs
