BASIC可程序化硬件说明手册
消耗积分:0 | 格式:pdf | 大小:6.86 MB | 2011-04-26
yiyangwei
分享资料个
Important notes:
· This manual should be used in conjunction with a "TIDE and Tibbo BASIC
Manual" -- a separate manual that documents Tibbo BASIC, TIDE software,
hardware "platforms", and everything else required for successful development
of Tibbo BASIC applications.
· This manual does not include any information on fixed-function,
non-programmable Tibbo devices, such as the original EM100 module or the
DS100 serial device server. The data on these devices can be found in the
"Serial-over-IP Solutions Manual" -- a separate document.
· Some Tibbo devices are dual-use in nature. Depending on the loaded firmware,
any dual-use product can be a fixed-function, serial-over-IP device, or a
BASIC-programmable controller. Dual-use devices are documented in the
present manual as well as the "Serial-over-IP Solutions Manual". The present
manual describes each such device as a BASIC-programmable one, while the
"Serial-over-IP Solutions Manual" describes the same device as a serial device
server.
评论(0)
发评论
下载排行榜
