MC35i数据资料
消耗积分:0 | 格式:pdf | 大小:2.92 MB | 2011-05-30
分享资料个
Throughout the document, the GSM engines are referred to as ME (Mobile Equipment), MS (Mobile Station), TA
(Terminal Adapter), DCE (Data Communication Equipment) or facsimile DCE (FAX modem, FAX board). When
the Siemens product names are required to distinguish the two models, MC35i is short for the engine type and
MC35iT for the terminal.
To control your GSM engine you can simply send AT Commands via its serial interface. The controlling device
at the other end of the serial line is referred to as TE (Terminal Equipment), DTE (Data Terminal Equipment) or
plainly 'the application' (probably running on an embedded system).
All abbreviations and acronyms used throughout this document are based on the GSM specifications. For definitions
please refer to TR 100 350 V7.0.0 (1999-08), (GSM 01.04, version 7.0.0 release 1998).
评论(0)
发评论
下载排行榜
