FFT Processor,Project report
消耗积分:5 | 格式:rar | 大小:333 | 2009-05-14
分享资料个
LIST OF FIGURES
Chapter 1-Introduction to VHDL
1.1 Introduction 1
1.2 Advantages of VHDL over other Hardware
Description Languages.. 1
1.3 VHDL : The Language 2
1.3.1 Entity Declaration.. 3
1.3.2 Architecture Body.. 3
1.3.3 Configuration Declaration.. 7
1.3.4 Package 8
1.3.5 Testbench 9
Chapter 2-High Level Design Flow. 10
2.1 HDL Capture 10
2.2 RTL Simulation 10
2.3 VHDL Synthesis.. 12
2.4 Functional Gate Level Verification. 13
2.5 Place and Route... 13
2.6 Post Layout Timing Simulation.. 15
Chapter 3-Illustration of VHDL.. 16
3.1 The IEEE floating-point standard 16
3.2 The Addition Process.. 17
3.3 Hardware Implementation of Floating-Point Adder 19
3.3.1 Block Diagram of the Adder.. 19
3.3.2 The Subtractor Unit 20
3.3.3 The Swap Unit 21
3.3.4 The Shifter Unit.. 22
3.3.5 The Summer Unit 23
3.3.6 The Normalize Unit. 23
3.3.7 The Control Unit. 24
3.3.8 The Testbench for the adder 28
Chapter 4- The Fourier Transform 30
4.1 The Discrete Fourier Transform... 30
4.1.1 An Illustration.. 30
4.1.2 Types of Fourier Transforms... 31
4.1.3 Notation and Format of the Real DFT. 33
4.1.4 DFT Basis Functions 34
4.1.5 Analysis, Calculating the DFT. 37
4.2 The Fast Fourier Transform. 37
4.2.1 Comparison of Real DFT and Complex DFT. 38
4.2.2 How the FFT works 39
4.3 Synthesis, Calculating the Inverse DFT.. 42
4.4 Illustration of the DFT and IDFT in Matlab 44
Chapter 5-Architectural Design of the FFT Processor 46
5.1 Block Diagram of the FFT Processor.. 46
5.2 Butterfly Processing Element.. 48
5.3 Address Generation Unit. 50
5.3.1 Butterfly Generator 52
5.3.2 Stage Generator.. 52
5.3.3 Stage Done_IO Done Block... 52
5.3.4 IO-Address Generator 53
5.3.5 Base Index Generator. 53
5.3.6 The Shifters 54
5.3.7 ROM Address Generator... 54
5.4 Controller. 55
5.5 RAM and ROM... 55
Chapter 6-RTL Simulation of the FFT Processor... 56
Chapter 7-Synthesis of the FFT Processor.59
Chapter 8-Conclusion. 60
APPENDIX A-Code Listing.. 61
APPENDIX B-Synthesis Results... 101
References .112
评论(0)
发评论
下载排行榜
