The data plane of the reference design consists of a configurable multi-channel XBERT modulethat generates and checks high-speed serial data transmitted and received by the MGTs. Eachchannel in the XBERT module consists of two MGTs (MGTA and MGTB), which physicallyoccupy one MGT tile in the Virtex-4 FPGA. Each MGT has its own pattern checker, but bothMGTs in a channel share the same pattern generator. Each channel can load a differentpattern. The MGT serial rate depends on the reference clock frequency and the internal PMAdivider settings. The reference design can be scaled anywhere from one channel (two MGTs)to twelve channels (twenty-four MGTs).
