71M6533,71M6533G,71M6533H,71M6534,71M6534H电表IC
消耗积分:1 | 格式:pdf | 大小:1.84 MB | 2012-02-20
分享资料个
 The Teridian™ 71M6533 and 71M6534 are third-generation polyphase metering systems-on-chips (SoCs) with a 10MHz 8051-compatible MPU core, low-power RTC, flash, and LCD driver. The Single Converter Technology® with a 22-bit delta-sigma ADC, seven analog inputs, digital temperature compensation, precision voltage reference, and a 32-bit computation engine (CE) supports a wide range of metering applications with very few external components.
评论(1)
发评论
tshdoor 2012-09-10
0 回复 举报
OK,FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 收起回复
下载排行榜
全部1条评论
