手机模块指南
消耗积分:5 | 格式:rar | 大小:433 | 2009-05-15
vinww特烦恼
分享资料个
手机模块指南:手This document gives recommendations for WISMO Quik Q3106 module
integration in a wireless application.
It gives some recommendations for:
• Baseband design rules and typical implementation examples,
• RF design rules and typical implementation examples
• Mechanical constraints for module fitting,
• PCB routing recommendations,
• Test and download recommendations.
It also gives some part references and suppliers.
WISMO QUIK Q3106 module is available under three GSM/GPRS Class 10
versions:
• Q3106A: E-GSM/GPRS 900/1800 MHz version with 16 Mbits of Flash
memory and 2 Mbits of SRAM (16/2)
• Q3106B: E-GSM/GPRS 900/1800 MHz version with 32 Mbits of Flash
memory and 4 Mbits of SRAM (32/4)
• Q3106D: E-GSM/GPRS 900/1800 MHz version with 64 Mbits of Flash
memory and 8 Mbits of SRAM (64/8). This configuration will be available
for handset application and vertical application where UART2 is not used.
评论(0)
发评论
下载排行榜
