The MAX2042A single, high-linearity upconversion/downconversion mixer provides up to +33dBm inputIP3, 7.25dB noise figure, and 7.2dB conversion loss for1600MHz to 3900MHz GSM/EDGE, CDMA, TD-SCDMA,WCDMA, LTE, TD-LTE, WiMAXK, and MMDS wirelessinfrastructure applications. With an ultra-wide 1300MHzto 4000MHz LO frequency range, the IC can be used ineither low-side or high-side LO injection architectures forvirtually all 1.7GHz to 3.5GHz applications (for a 2.5GHzvariant tuned specifically for low-side LO injection, referto the MAX2042).
