The CD4070BC employs complementary MOS (CMOS) transistors to achieve wide power supply operating range, low power consumption, and high noise margin, the CD4070BC provide basic functions used in the implementation of digital integrated circuit systems. The N- and Pchannel enhancement mode transistors provide a symmetrical circuit with output swing essentially equal to the supply voltage. No DC power other than that caused by leakage current is consumed during static condition. All inputs are protected from damage due to static discharge by diode clamps to VDD and VSS. Features Wide supply voltage range: 3.0V to 15V High noise immunity: 0.45 VDD typ. Low power TTL compatibility: Fan out of 2 driving 74L or 1 driving 74LS Pin compatible to CD4030A Equivalent to MM74C86 and MC14070B
