As the block diagram in Figure 1 illustrates, the PCA8550 consists of eight stages which are conveniently grouped into one integrated circuit. These 8 stages are listed below. The PCA8550’s Eight Stages: 1. Nine internal pull–ups (10– 150 W) on the four pass-through inputs to avoid floats 2. I2C interface logic to communicate between the two I2C inputs and the 5-bit E2PROM 3. A 5-bit E2PROM to store the packets transferred through the I2C inputs SCL and SDA 4. Five AND gates to drive the E2PROM outputs (Q0 – Q4) low upon override 5. A 4–bit mux to select between E2PROM outputs (Q0–Q3) and the pass–through inputs 6. A 1–bit latch to retain the value of the 5th E2PROM output, NON_MUXED_OUT (Q4) 7. A 1–bit inverter to enable this latch upon request (of the MUX_SELECT pin) 8. A 4–bit buffer to convert the 3.3V CMOS multiplexer outputs into 2.5V outputs
