X9241 EEPOT数字电位器和IIC串行端口如何接口
消耗积分:5 | 格式:rar | 大小:38 | 2009-05-27
贾飞世
分享资料个
This application note demonstrates how the X9241 E2POT digital potentiometer, with its two-wire serial interface, can be used on a microcontroller port using
dedicated I2C control hardware. Although the X9241 does not attempt to follow the standard I2C protocol, it is possible, with some restrictions, to implement all of the X9241 instructions using I2C control hardware. The restrictions to interfacing the X9241 depends on the I2C control hardware being used. Specifically, it depends on whether the I2C control hardware is bit-wide or bytewide orientated.
评论(0)
发评论
下载排行榜
