MAXQUSBJTAGOW评估板软件
消耗积分:0 | 格式:zip | 大小:0.00 MB | 2012-11-02
dplion
分享资料个
MAXQUSBJTAGOW评估板软件:关键特性 Easily Load and Debug Code Interface Provides In-Application Debugging Features Step-by-Step Execution Tracing Breakpointing by Code Address, Data Memory Address, or Register Access Data Memory View and Edit Supports Logic Levels from 1.1V to 3.6V Supports JTAG and 1-Wire Protocols Each Adapter Has Its Own Unique Serial ID, Allowing Multiple Adapters to be Connected Without COM Port Conflicts Has In-Field Upgradable Capability if Firmware Needs to be Upgraded Enclosure Protects from Shorts and ESD
评论(0)
发评论
下载排行榜
