TSH150 and TSH151 are very high speed voltage feedback operational amplifiers, using SGS-THOMSON Microelectronics BiCMOS process. They feature a 200V/ms slew rate, 150MHz gain bandwidth product and 20ns to 70ns settling time to 0.1% (2V step). The TSH151 has the added advantage of MOS inputs. A 45o typical phase margin, for unity gain, makesthem easy to use as followers for buffer applications with 50W loads for example. Additional information may be obtained from the respective data sheets. A demonstration board is available for device evaluation (order code SLDB-001A).
