Fully-Differential Isolation Amplifier AMC1200
消耗积分:1 | 格式:pdf | 大小:1170KB | 2014-12-02
loooooooi
分享资料个
The AMC1200 is a precision isolation amplifier with an output separated from the input circuitry by a silicon dioxide (SiO2) barrier that is highly resistant to magnetic interference。 This barrier has been certified to provide galvanic isolation of up to 4000 VPEAK according to UL1577 and IEC60747-5-2. Used in conjunction with isolated power supplies, this device prevents noise currents on a high common-mode voltage line from entering the local ground and interfering with or damaging sensitive circuitry。
评论(0)
发评论
下载排行榜
