Application Note 222 Using the DS2770 as a 3-Cell NiMH Charger
消耗积分:2 | 格式:pdf | 大小:117KB | 2015-04-16
duruifeng
分享资料个
In order to achieve maximum efficiency when charging a battery, it is necessary to implement charging techniques geared specifically for a battery cell chemistry. For example, negative ∆V or dT/dt termination criteria is used for NiMH cells, while a CC/CV or pulsed-charged technique is appropriate for rechargeable lithium cells.The DS2770 battery monitor and charge controller can be configured to charge either NiMH or Li+ cells.This application note addresses several key things to consider when using the DS2770 to charge a NiMH battery pack.
评论(0)
发评论
下载排行榜
