金属管浮子流量计中电容式角位移传感器的研究
消耗积分:5 | 格式:rar | 大小:446 | 2009-07-18
分享资料个
本文针对新型金属管浮子流量计中电容式角位移传感器的研究,详细阐明电容式角位移传感器的设计方法及原理,并配合一种抗寄生干扰的微小电容测量电路,最终实现对浮子流量计中电容式角位移传感器转动角度的精确测量。在30°测量范围内,可实现精度0105°。
关键词:  金属管浮子流量计 电容 角位移传感器 抗寄生干扰 误差
Abstract : Based on the experimental study of the capacitive angular position sensor of the metal tube variable area rotameter , this paper describes a designed method and principle of capacitive angular sensor & successful combination of intrinsically stray - immune capacitance measuring circuit so as to obtain high ac2 curacy (0105°) ,and resolution (0101°)over the relative measurement range of 30°.
Keywords :Metal tube variable area rotameter , capacitor , angular - position sensor , parasitical stray immune , error.
评论(0)
发评论
下载排行榜
