Two-Way_Audio_Communications_using_the_CC1110_or_CC2510_and_the_TLV320AIC26_Codec
消耗积分:0 | 格式:pdf | 大小:782KB | 2016-01-06
吴建伟
分享资料个
This application note describes a two-way audio communications link between a ‘Master’ and a ‘Slave’, based on the Texas Instruments CC1110 or CC2510 Systemon-Chip Low Power RF Transceiver ([1] and [2]) and the TLV320AIC26 Codec [5]. Use is made of the µ-Law compression/expansion algorithm implemented in CC1110 (CC2510) hardware.
评论(0)
发评论
下载排行榜
